Re: Pallets to prop up the tractor?
Posted by nballen on November 06, 2006 at 09:10:11 from (198.246.171.252):
In Reply to: Pallets to prop up the tractor? posted by Mike CA on November 06, 2006 at 08:53:32:
The big drawback to pallets is the size (typically what...42 x 48"?). So they will be very stable, but hard to work around.
You would also need to secure the stack, so that the pallets can't shift to one side and tip over.
I've never split a tractor, so I can't be too helpful, I'm afraid.
However, I have used blocking in various forms...6x6, 8x8, etc. With a firm foundation (24" x 24" x 1/2" plywood, on level concrete, etc) blocking could be ok.
Hmmm...What about heavy auto jack stands with a 4x4 (3 ft long) across the two of them? Bolted to the jack stands? Thinkin' "out loud" here.
Nathaniel
