Re: M--Countershaft seal
Posted by dcw on November 06, 2006 at 09:45:30 from (156.34.204.137):
In Reply to: M--Countershaft seal posted by JWalton on November 04, 2006 at 20:04:06:
I just checked my book aswell,no part #.As much as your not going to want to do it,you may have to take the nut off and dig the old seal out and get a # off it.The seal runs on the nut,you may need that too.Mine leaks bad enough I have to catch the oil in a bucket.But the tractor has larger issues at the moment.....
