Re: Pallets to prop up the tractor?
Posted by old on November 06, 2006 at 09:50:47 from (4.244.57.150):
In Reply to: Pallets to prop up the tractor? posted by Mike CA on November 06, 2006 at 08:53:32:
Pallets are good to put parts on but not hold a tractor up. If you can't afford the right jacks then go and buy some rail road ties and cut them down to size for what you need. Then stack them in a criss/cross way to keep them from falling. Cheap but also very strong
