Re: Pallets to prop up the tractor?
Posted by kejab21 on November 06, 2006 at 16:43:54 from (64.19.80.102):
In Reply to: Pallets to prop up the tractor? posted by Mike CA on November 06, 2006 at 08:53:32:
If you use pallets they have to be hard wood. I work at Kraft in distrbution. We lost a loaded trailer off our yard truck. the way they get it off the ground is lift it with cables with a big wrecker, put the pallets under it back far enough so we can get the yard horse back under it. We are talking over 40000lb. They hold alot of weight.
