Re: Governor Question
Posted by Red Dave on November 07, 2006 at 12:04:34 from (66.216.141.163):
In Reply to: Governor Question posted by A Newbie on November 07, 2006 at 10:21:35:
Scotty has it right.
You can get stock sizes of brass & bronze bushings at an industrial supply like McMaster-Carr or a local machine shop. Also told that Lowes stocks them too.
It's not a hard job, but if you don't want to tackle it yourself, it would be an easy job for a machine shop to do for you.
A Case/IH dealer can get you most everything else in that governor, like springs, bearings etc.
