Re: 48 Cub Just Died Need Help
Posted by City-Boy McCoy on November 07, 2006 at 14:58:31 from (70.149.229.236):
In Reply to: 48 Cub Just Died Need Help posted by Joe Carter on November 07, 2006 at 14:00:19:
Start with the three basics of internal combustion engines: 1) Compression; 2) Spark; 3) Fuel. One at the time in that order.
Wild guess: It sounds like a fuel starvation problem as evidenced by the backfire - or pop - which is an indication of a lean condition. Can also indicate timing, although if it ran for perfectly for 2-3 hours, that is doubtful.
mike
