Re: 48 Cub Just Died Need Help
Posted by Ron Andersson on November 07, 2006 at 15:49:21 from (170.215.220.171):
In Reply to: 48 Cub Just Died Need Help posted by Joe Carter on November 07, 2006 at 14:00:19:
Inside your fuel tank between the bottom of the tank and the sediment bowl there is a fine screen that collects everything! try unhooking your fuel line from the carb and blow air back up into the tank thru the fuel line(not too much pressure)loosen the fuel cap first and usually you will see alot of sediment come back into the fuel tank,you might have to drain and clean a couple of times.This "little "problem drove me nuts for a while and and old farmer told me to try it and it worked!Good Luck!
