Re: 1466 hydraulics
Posted by dustin braun on November 08, 2006 at 04:31:53 from (66.231.24.250):
In Reply to: 1466 hydraulics posted by Dustin Braun on November 07, 2006 at 19:33:29:
Thanks for the reply, the loader valve is for open center, I won't use the power beyond on the loader valve because tractor doesnt have 3pt, and if I use second tractor valve for an implement I will just kick the first valve into nuetral. I was mainly worried about leaving the lever in, with oil flowing constantly, but with oil cooler I guess it shouldn't be any different than running the hyd. fan on air planter.thanks again.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
