Re: Got A Little Problem
Posted by NO tools on November 09, 2006 at 05:24:09 from (71.79.44.154):
In Reply to: Got A Little Problem posted by Allan In NE on November 09, 2006 at 04:24:15:
ALLAN YES we have on all our 706 966 & 1066. NOW this is going to sound way out in the country but think about this.There is a brass bushing in there they call it oilite.This thing gets gumd up and stiky. we took the bolt out of the handle measured the depth of the hole.took the cowl off and put the handle back to TA position.NOW we took and drilled a 1/8 hole down through the bracket and shaft till we drilled into that bolt hole.NOW drill a small hole clear through the handle bolt. ON the head enlarge the hole enough to tap and place small grease fitting.NOW when you are done and put it back in direct drive your two small hole are not lined so you can push grease in around the shaft.I know someone is going to bet me down for this.
