Re: Farmall A Oil Pan Drain Plug
Posted by old on November 09, 2006 at 14:57:09 from (4.244.90.62):
In Reply to: Farmall A Oil Pan Drain Plug posted by John P. on November 09, 2006 at 14:30:33:
Case/IH should have them, but if not I have a B thats a parts tractor and I still have the engine so the plug is still there. E-mail is open
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
