Re: farmall smta not starting?
Posted by Nat 2 on November 10, 2006 at 05:35:12 from (64.80.108.53):
In Reply to: farmall smta not starting? posted by lester l on November 09, 2006 at 20:38:40:
It's very hard to tell what you're saying. What gets hot now? When does it get hot?
Does it get hot when you connect the battery?
OR
Does it happen when you pull the ignition switch?
OR
Does it get hot when you try to start the tractor?
It's very simple: You have a short circuit. 99.9% of the time it is a wire that has rubbed bare, but if it only happens when you try to start the tractor, then the saddle switch on the starter is bad, and is shorting out directly to the tractor's frame.
700 Amps will fry most of the wires on the tractor, so you should see some smoke in the 30 seconds before the battery runs down.
700 Amps is also enough to boil the battery and cause it to explode.
