Re: YIKES!!!!!!
Posted by Brownie 45 on November 11, 2006 at 07:21:05 from (207.177.82.236):
In Reply to: YIKES!!!!!! posted by RoninKS on November 10, 2006 at 23:23:52:
The landlord has a JD tractor [2630] which was sitting out in the sun at about 80 degrees after a cool morning of around 30 degrees. He found oil all over the scraper & tractor which had previously been clean. Turned out to be a hose blew out from pressure buildup due to the heat. Look around your tractor to see if anything like this could have happened.
