Re: YIKES!!!!!!
Posted by Janicholson on November 11, 2006 at 08:24:14 from (66.173.50.174):
In Reply to: Re: YIKES!!!!!! posted by RoninKS on November 11, 2006 at 01:05:04:
Ron,
The precursor stocks that ATF are made from are more parafin based than the mineral oil that is common to motor oil and Gear lube. There may also be seal conditioners and ingredients in it not found in other oils. However it is not prone to causing seal deterioration in any drastic sense.
At about the same time (to keep the experiment controlled), take a sample of the "mess" oil and put it on clean printer paper. Next to its spot put samples of the other oils from the tractor. Watch for time to spread, color, and smell. If no match, not your oil! JimN
