i have a char-lynn two way valve on my m with the 3 point. pressure out from the belly pump into the spool valve, the return is plumbed into the belly pump drain with a pipe tee. put a close nipple on the center of the tee so it screws into the pump drain, then hook the return line to one side of the tee. put a pipe plug in the other so it is easier to drain the pump if need be. something else that is handy if you want, on the control rod for the pump, instead of just wiring it to the full on position, weld a short piece of 5/16 either a bolt or round stock in the full on position, so it looks like the other stop. that way when you want to pressurize the pump, you pull the rod back and hook it on the notch!! pretty tricky!!!!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
