Re: B-250 Injection Pump
Posted by Bob on November 11, 2006 at 18:49:38 from (69.178.229.154):
In Reply to: Re: B-250 Injection Pump posted by JB On on November 11, 2006 at 18:33:19:
I am more familiar with the English Ford diesels, which use a similar pump.
On those, when you pull the "kill" cable, you can feel the "rack" inside the pump move from the "full-fuel" start position, to the "fuel cut-off" position. How is the "kill" or shutdown set up on your's set up? You should be able to feel the same "load" on the "kill" button, as the "rack" slides back and forth.
Years ago, I got a Ford Major Diesel that had sat for a long time. The injection plungers were so sticky they would not return. I partially dis-assembled the pump, and freed the plungers with carb cleaner and/or WD-40. It's been over 20 years, and I don't recall all the details, but the tractor is still in running order today.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
