Re: Hysler, Hiesler, ???? overdrive
Posted by r4etired on November 11, 2006 at 19:07:52 from (152.163.100.65):
In Reply to: Hysler, Hiesler, ???? overdrive posted by Steve Kroll on November 10, 2006 at 20:03:23:
Heisler, M&W. Behlen all made what is called the 9 speed transmission. They mated a shiftable larger gear to the constant mesh gear on the top shaft, also smaller gear onthe lowershaft. they all were about a 30% increase in the 4 speeds.as 5th is direct on the top shaft it was not affected. Linkage on the right M&W,left side linkage Heisler. Cable operated, Behlen
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
