Re: WD6 Rear Main Oil Seal !!
Posted by KEB on November 12, 2006 at 10:13:03 from (72.19.170.5):
In Reply to: WD6 Rear Main Oil Seal !! posted by David Cohrs on November 11, 2006 at 19:33:42:
Hi, I also have a 1950 WD-6. Here's what the manual says about that seal: "Oil seals are provided at the front and rear of the crankshaft. The front seal is combination felt and leather, located in the crakcase front cover; assemble with the felt portion of the seal toward the outside. The rear oil seal is a split type felt; the flywheel must be removed to replace the seal. When an oil leak occurs between the flywheel and crankcase, check the fit of the expansion plug (2-1/8 inch) at the rear of camshaft; also check the rear main bearing for excessive wear, and replace all gaskets, and felt of the rear oil seal." The book also says the "clutch is removable through top of frame after removing gas tank, etc., ..." Not sure whether you could get the flywheel off through the same opening or not. Good luck. Keith
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
