2000 Loader on 2424 - hydraulics
Posted by Doc Larry on November 12, 2006 at 16:21:38 from (216.146.101.227):
If anyone out there has an IHC 2000 Loader on a 2424 or 424 IHC tractor, I'd like to know where your hydraulic filter (for the front mounted pump) is located, and if it is plumbed into the return line from the valve bank, or into the suction line to the pump.
Thanks in advance.....
Larry
