Re: WD6 Rear Main Oil Seal !!
Posted by D Slater on November 13, 2006 at 05:25:01 from (64.12.116.65):
In Reply to: WD6 Rear Main Oil Seal !! posted by David Cohrs on November 11, 2006 at 19:33:42:
For updated seal, are you refering to the neopream seal. If so the upper and lower housings seals go in have to be changed also if you have rope seal now. Your tractor may have update already because I have found several in MD, tractors. Think IH started installing in tractors sometime during 400 D tractor production in farmalls. Think the neopream seal is over a hundred bucks,ben a while since I checked around though.
