Farmall Tractors Discussion Board
Re: Super A Blade..also a front loader!
Posted by Mike on January 31, 2000 at 09:10:47 from (198.133.22.69):
In Reply to: Super A Blade..also a front loader! posted by Raymond '54 SAV on January 31, 2000 at 08:03:34:
I saw a homemade device a month or
so ago for a front mounted blade.
Basically there was a frame attached
to the front, with a hyd. cyclinder,
and then the blade attached to set
up. It was designed much like a plow
set up on a pick up truck. It looked
pretty slick to me, and it did the
job. I have a picture of a front
loader that was made to fit the
Farmall 100, if your interested let
me know, and I will send it to you.
Post A Followup
: Re: Re: Super A Blade..also a front loader!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
