Re: Return of the H starting problem
Posted by hbauer from Vt on November 14, 2006 at 15:06:09 from (12.75.172.213):
In Reply to: Re: Return of the H starting problem posted by Bob on November 11, 2006 at 19:40:21:
Continuing the saga, I am down to a short in the distributor. I sanded the points and swabbed them with alcohol. No change.
I did replace #4 gauge cable from battery in favor of a #1...the cranking speed change is dramatic!
I think Bob's suggestion may be right. I suspect the insulated fitting which goes through the distrib from the coil wire to the condensor.
Anyone know where I can get this insulted fitting?
p.s. after doing all the above, it cranked much faster and the engine caught momentarily then died. The points are clearly still working only intermittantly.
