Re: Hard Starting WD-6 -HELP-
Posted by KEB on November 14, 2006 at 18:47:16 from (72.19.170.5):
In Reply to: Hard Starting WD-6 -HELP- posted by Tyler Cohrs on November 14, 2006 at 17:50:15:
Before you tear into the carb, check the starting linkage adjustments. There's a cam in the carburetor that holds the float valve in the closed position when running on diesel. If it isn't turning far enough, it may not be allowing sufficient fuel into the float chamber.
Keith
