Re: How To Operate a T/A
Posted by K.B.-826 on November 14, 2006 at 19:28:44 from (68.115.91.164):
In Reply to: How To Operate a T/A posted by City-Boy McCoy on November 14, 2006 at 18:06:33:
There are two types of TA's. The mechanical TA is used in the tractors with the 5-speed transmission, from the Super MTA all of the way up to the 686 which was last built in 1981. The hydraulic TA is used in the tractors with the 3 or 4 speed/high-low-reverse range transmission, from the 706 all of the way up to the 6788. On all tractors, when the lever is ahead, you are in direct drive. When the lever is pulled back, you are in TA. With any TA-equipped tractor, the main engine clutch is in no way used while shifting the TA. That is the main point of the TA- to change speed or increase pulling power without declutching/stopping or otherwise interupting the flow of power from the engine to the wheels. Just grab the lever and shift. With both TA's, I think it is best to move the lever as fast as you possibly can, to avoid slippage. With any TA, proper linkage adjustment goes a long way towards how long the unit will last. Adjustments are very critical and must be followed to the letter. Changing the transmission fluid at the specified interval is also very important, especially with the hydraulic TA. Remember, the mechanical TA will provide no engine braking when the lever is back (in the TA position). This means that the tractor will freewheel downhill. If this should ever happen to you, try your best to bring the tractor to a stop with the brakes. If you gain too much speed freewheeling and throw the lever ahead into the direct drive position, the unit will self-destruct. With the hydraulic TA, a brake pack is used to keep the tractor from freewheeling in the TA position. If you try to use the hydraulic TA as an engine brake, such as flying in off of the road with a loaded wagon and pulling the TA lever back to slow down, you will fry the brake pack. Another common misunderstanding is that the TA will last forever if you never use it. This is not true, since flat spots will wear into the overrunning clutch rollers if you do so, then it will slip in the TA position if someone decides they want to use it. Use it or lose it.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
