Re: Farmall A Drawbar Bolts
Posted by NDS on November 15, 2006 at 13:53:26 from (64.12.116.65):
In Reply to: Farmall A Drawbar Bolts posted by John P. on November 14, 2006 at 13:35:02:
Do not think you will find new bolts from normal sources to match originals most letter series bolts were DOT HEADS with dot in center. Have seen variation of dot heads that had center dot with 3 slashes similar to grade 5 but slashes are spaced 120 degrees and go from dot to outside of head. Saw an add (I think in Red Power) for reproduction dot head bolts recently.
