Re: Trans oil change in a Super A
Posted by billde on November 16, 2006 at 06:42:51 from (66.249.39.139):
In Reply to: Trans oil change in a Super A posted by Brett Chesshir on November 16, 2006 at 05:49:15:
There is a drain plug for the trans under the tractor, draining the pto does not drain the trans. remove the final drive pans to drain, replace gaskets. fill plug is right above where the pans attatch to the drives. use 90 wt or 85-140.
Hy-tran is correct for the hydraulics.
