Re: Air lift questions
Posted by Jim Becker on November 16, 2006 at 07:13:28 from (71.164.210.94):
In Reply to: Re: Air lift questions posted by Roger Mills on November 15, 2006 at 20:04:27:
If the cylinder is mounted vertically next to the radiator, it is set up for a cultivator. If it is nearly horizontal, along the left side of the tractor, it is set up for a plow. Same basic setup was used for several different cultivators or several different plows. These 2 positions were probably the most common uses of the lift but other positions were used for other equipment.
