Re: Coil Wiring
Posted by Janicholson on November 16, 2006 at 14:39:09 from (66.173.50.94):
In Reply to: Coil Wiring posted by NCFarmall on November 16, 2006 at 12:58:21:
From the switch wire connect to one side of the resistor. From the other side of the resistor attach to the positive side of the coil. From the ngative side of the coil attach to distributor/points.
If you are using a solenoid for starting, the I terminal of the solenoid (small post next to the S post) run a wire to the coil positive side. That should do it, JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
