Farmall seat wobble
Posted by Narrowfarm on November 16, 2006 at 16:32:57 from (69.113.66.237):
Hi,I have a farmall H with the seat that has the big spring & the shock absorber between the legs in front of the spring.I took out the long pivet bolt. There is a sleve that looks in good shape but i believe there should be some rubber bushing at each end of the sleve.Am I correct? & how do you install them and where do i get them & about price? thanks john
