Re: lights for 400
Posted by Janicholson on November 17, 2006 at 06:18:58 from (199.17.6.122):
In Reply to: Re: lights for 400 posted by SDE on November 17, 2006 at 03:25:38:
Most lights have a parabolic reflector behind the filement that causes the reflected light to head out in a pretty tight beam (especially if it has a deflector in front of the filement inside the bulb). the bulbs that provide wide angle illumination have various bumps and ridges on the lense that change the angle to a wide pattern. The only caution is that the dim position can only handle the stock current draw without burning up. That is why I suggested that to make the situation more "Illuminated" it would be best to add a circuit. No matter what conventional bulb is choosen the same watts will produce no more light. JimN
