Re: IH 1086 Park Problem???
Posted by Erik in Wi on November 17, 2006 at 09:12:07 from (65.162.45.164):
In Reply to: IH 1086 Park Problem??? posted by bneuhart on November 17, 2006 at 07:46:55:
The park brake could be any number of things. The linkage could be binding or out of adjustment, something could be broken or missing in the transmission. My 1086 is hard to get in and out of park, but my 1486, which has had an upgraded shift linkage system put in it will almost fall into park.
Did the park brake ever work?
If the light on the dash is an arrow pointing down with dots behind it, that is not a coolant level light(1086s don't have a coolant level sensor) it is the air intake light. Change the air filter (DON'T CLEAN IT).
Hope this helps
Erik in WI
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
