Re: Farmall Cub Battery Hookup:
Posted by Bob on November 17, 2006 at 14:46:58 from (69.178.229.154):
In Reply to: Farmall Cub Battery Hookup: posted by J. W. Bishop on November 17, 2006 at 14:25:46:
If it still has a generator, (rather than someone having put an alternator on it), you can switch it back to (+) ground. You MUST polarize the generator AFTER swapping the battery leads, but BEFORE starting the engine for the first time with the battery leads swapped. If battery ignition, verify that the (-) terminal an the coil will be fed from the ignition switch, and the (+) coil terminal will connect to the distributor (points/condensor) for (+) ground operation. Myself, if it is starting well and charging, I would leave it "as-is", 'cause there's always a small chance the polarity of the generator won't switch, even after "polarizing", and, if this happens, all the smoke can be let out of the generator and regulator in a quick hurry, after the tractor is started up and later shut down. GOOD LUCK, if you decide to try it. Probably well over 90% of the time, the polarity swap will work with no problems, AS LONG as the generator is polarized before being started again.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
