Re: F-12 serial # FSR 649
Posted by Farmallgray on November 17, 2006 at 18:01:06 from (152.163.100.65):
In Reply to: F-12 serial # FSR 649 posted by moseed on November 16, 2006 at 16:00:53:
My guess is that the "R" stands for replacement and the 649 is the serial number for replacement engines. Replacement engines were probably assigned serial #s just like tractor and power unit engines. So my guess (assuming that they started with 501 like everything else) is that your engine is the 149th replacement F-12 engine.
I do have some IHC documentation that lists all the parts of the conversion kit.
