Re: Farmall 560 and 660 Diesels
Posted by billde on November 17, 2006 at 18:50:08 from (66.249.39.139):
In Reply to: Farmall 560 and 660 Diesels posted by Weldin Man on November 17, 2006 at 17:40:00:
injectors are interchangeable between early style 560 & 660, same with late style. You cannot however mix early & late styles. The pumps look the same assuming they are the same style. You can turn the rpm's up on the 560 but not sure what you will get for HP without opening up the torque screw.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
