Re: rebuilding a Super C
Posted by gene bender on November 18, 2006 at 05:17:52 from (67.55.226.214):
In Reply to: rebuilding a Super C posted by riverbend on November 18, 2006 at 04:21:17:
Sounds like yours has a busy life. I would pull the engine put it on a stand get crank reground new hi-dome pistons rings and sleeves run the head thru shop and when done you will have a new engine that will last as long as you will have use for it. You can get kits new pistons,rings,bearings,sleeves and gaskets for less than 500.
