Re: Kerosene vs Distillate
Posted by Nebraska Cowman on November 18, 2006 at 08:41:33 from (65.169.97.149):
In Reply to: Kerosene vs Distillate posted by Roger Mills on November 18, 2006 at 08:20:58:
No no no, distilate was a blend of all fuel grades, ending up something like light fuel oil or heavy gasoline. They changed the refining process and it is no longer. Kerosene is a close substitute. These heavier fuels will burn well in a spark combustion engine as long as it is hot enough to volitalise the fuel. The engines were low compression to reduce knocking.
third party image
Even bad boys are just as good as they can be
third party image
