Super c Henderson loader
Posted by Need To Know on November 19, 2006 at 08:25:26 from (64.19.80.101):
Can someone spell out how to plumb the hydraulics for my loader(I am ignorant)I have a hose coming from the bottom of the hydraulic block on the Super c touch control that goes to the port marked "out" on the loader control valve.The center port on the control valve goes to one loader cylinder with a jumper to the other cylinder.The Port marked "in" on the control valve is just flopping in the wind.I dont know where this goes.I am assuming it would return to the auxillary hydraulic tank I plumbed up to the fill port on the touch control.It seems me that the "in" and "out" are plumbed backward on the control valve.That is the way that the previous owner had them on his tractor(Or at least that is where they were plumbed up when I got the loader).Help!!!!!!!!
