Re: What do Ihave
Posted by D Slater on November 19, 2006 at 16:25:35 from (205.188.116.133):
In Reply to: What do Ihave posted by Bill Geer on November 19, 2006 at 14:53:50:
C 169 is a 300 engine. It will work in a H, but if its a utility the front engine cover is different than row crop and some bolts that hold cover to engine block are a bigger diameter. You can make the row crop cover work on utility block with not much problem. If tractor has a turned down manifold that could be a problem unless the one on your H is a replacement that will take a H or 300 carburator bolt pattern.
