Re: Farmall 560 died
Posted by El Toro on November 19, 2006 at 18:17:36 from (152.163.100.65):
In Reply to: Farmall 560 died posted by MaverickM23 on November 19, 2006 at 18:02:03:
I would install a new set of plugs. If it still won't start bring No1 piston to TDC on the compression stroke and the timing mark is aligned with the pointer. Then remove the distributor cap and see where the rotor is pointing. It should be at the No1 plug tower. If its way off
you may have jumped timing. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
