Re: 560 Wheatland steering box
Posted by toolz on November 19, 2006 at 21:36:17 from (66.158.169.70):
In Reply to: 560 Wheatland steering box posted by toolz on November 18, 2006 at 17:53:53:
Clark- Good luck finding those rims. I looked everywhere. I finally fixed the one bad one that I had- came out real good. The wheel centers will accept a beveled rim- you can get some 30" blanks and use clamps like a 400 (or others) to mount them. Won"t be original, but it will work. The other choice is to rivit your lugs on the new blanks, but if you break one, you"re screwed. I"ve sure had fun with my wheatland so far- good luck with yours.
