Re: SMTA Antifreeze in Oil
Posted by SproutW on November 20, 2006 at 12:39:20 from (209.174.86.35):
In Reply to: SMTA Antifreeze in Oil posted by Retcol on November 20, 2006 at 09:19:50:
Don't want to ruin your day but it's not uncommon for a head to have a crack and only leak when warmed up. Hook up a pressure tester to your radiator and put 8 lbs. of pressure in the system. With the pan off see if you can locate a leak. If it comes out of a cylinder then you know more than likely it's a headgasket or the head itself. You can borrow the pressure testers at most parts stores or make your own up with an acurate gauge. Gook luck and keep us posted.
