Re: ih weight amounts
Posted by Randy in NE on November 20, 2006 at 13:36:06 from (204.124.193.163):
In Reply to: ih weight amounts posted by garry lee on November 20, 2006 at 12:50:49:
The full weights weigh about 145 lbs. The half weights are about 1/2 each. The holes and slots and set up so that you can mount the first weight and secure it using the inner set of holes. Then you can add additional weights using the slots/holes around the outside of the weight. They are set up to use square headed bolts and then they won't turn in the holes.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
