Re: SMTA Antifreeze in Oil
Posted by r4etired on November 20, 2006 at 17:50:58 from (152.163.100.65):
In Reply to: SMTA Antifreeze in Oil posted by Retcol on November 20, 2006 at 09:19:50:
Not uncommon for the block to crack behind the sleeve on M thru 450,Scale build up in the block causing areas that don't transfer heat equally thus causing cracks.In most of the years of M's antifreeze was to expensive, so tractors were drained on cold nites thus increasing the lime and calcium deposits. pull the pan and you might be able to see if it is leaking between sleeve and block.
