Farmall Tractors Discussion Board
Re: Super A Blade..also a front loader!
Posted by Daniel on January 31, 2000 at 16:53:46 from (205.188.193.47):
In Reply to: Super A Blade..also a front loader! posted by Raymond '54 SAV on January 31, 2000 at 08:03:34:
I have seen a loader an a Super A before that was orignal IH. Model 1000 I think. Had one arm and two cylinders. It hooked into the factory hydraulic pump circuit with an adapter where the lines go into the hydraulic box under the gas tank.
Post A Followup
: Re: Re: Super A Blade..also a front loader!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
