Re: super a rebuild more questions
Posted by Hugh MacKay on November 21, 2006 at 14:44:32 from (209.226.106.59):
In Reply to: super a rebuild more questions posted by werowance on November 21, 2006 at 12:52:17:
werowance: I wouldn't look at water pump unless I were having circulation problems. My Super A has seen a lot of hours, sure you here them gurgling and bubbling after you shut them off, but they have been doing that for 50 to 60 years with no adverse effect. Thermosyphon was and still is a good cooling system.
Now there are a couple of exceptions, plugged water jacket, a radiator that is partially plugged, but those will still give problems with a water pump. If part of the water jacket is plugged off and no water goes there, even pumped water takes the easy route. If part of the radiator cores are plugged off neither systen will cool right.
There is also another exception, at least one guy here on YT had his radiator recored and the supplier could not get a proper core for thermosyphon, just maybe they are no longer available. He did have to add a pump. Adding the pump is no problem, just a straight forward bolt on. Problem comes at top finding a thermostat to fit and work properly. It can be done, and there are folks on here who have done it. I think geneb has.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
