Re: 300 to run smooth
Posted by old on November 21, 2006 at 15:59:38 from (4.244.6.217):
In Reply to: 300 to run smooth posted by Dick Davis on November 21, 2006 at 15:15:04:
Sounds like you have a gummed up carb. Pull the drian plug and the main jet. Then spray carb cleaner into the main jet and let it drain out the drain plug. Then close it back upand see if that helps
