Re: Correct sediment bowl size?
Posted by gene bender on November 21, 2006 at 18:23:48 from (67.55.226.214):
In Reply to: Correct sediment bowl size? posted by SuperA-Tx on November 21, 2006 at 17:49:39:
The long one and if you will notice the short one has different fittings. You need an original so the gas line will fit without changes in the present line.
