Re: super a rebuild more questions
Posted by gene bender on November 21, 2006 at 18:39:03 from (67.55.226.214):
In Reply to: super a rebuild more questions posted by werowance on November 21, 2006 at 12:52:17:
If you have replaced the sleeves you now have a clean block as without a doubt you found crud at the bottom of the old sleeve where the water drains down thru the four holes so now that your system is nice and clean you shouldnt have any problems. Mite want to check temp when engine has warmed up real good temp will be around 165 when you take off the radiator cap and check. A water pump can be installed but not realy needed with a clean block.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
