Re: Farmall Regular Govenor
Posted by Kevin LA-CA on November 24, 2006 at 06:53:44 from (68.68.234.54):
In Reply to: Farmall Regular Govenor posted by CTJohn on November 23, 2006 at 17:30:42:
John - I am not an expert, but here is how I would start.
Early (if not all) Regulars were governed at full throttle only. Yours may be this way. To identify, mine has the throttle linkage that cross to the left of the engine and connecting to a pod in front of the carb. Also, since you describe the adjustment knob, I believe yours falls into this category.
1. How do I confirm that the govenor is operating correctly?
> If yours is governed at full throttle, open it up and drive up a hill. You should hear the engine growel more. Apply brakes for a short period to load futher.
2. How do I check the adjustment? I do notice a round tail (aluminum piece extension) in the rear of the govener which when turned makes no difference.
> This piece (pot metal actually) sets the full throttle speed. Counter clockwise is slower. You can use this to set the desired throttle speed for wood cutting.
3. Could the throddle linkage be worn enough to cause the govener to not operate? How do I check it?
> Yes, but more likely broken weight or worn weight pins, etc... I would remove the oil fill casting. Shine a flashlight and inspect while some one turns the engine. Take a screwdrivers and work the linkage.
4. Suppose I will need to retime her if I remove the govenor?
> Yes, but this is not too tough ;)
5. At what throddle speed is best for cutting? I am cutting at approximately 3/4 throddle speed.
> Sounds reasonable, but for the governor to work you need to run wide open throttle. Adjust the desired speed with the adjustment knob. I think max rated speed is 1100 rpm, turn to set to ~900 or so.
Hope this helps. Email is open if you have more questions.
