Re: more cranking power for super c
Posted by John T on November 25, 2006 at 08:02:20 from (66.244.90.5):
In Reply to: more cranking power for super c posted by ole ed on November 25, 2006 at 06:47:28:
Ed, Im NOT a fan of those 8 volt set ups (ESPECIALLY on smaller easy cranked tractors like yours), if you insist on changing voltage for faster crankind Id go ahead to the standard 12 instead of that oddball 8 volt system. Its indeed true if you used two six volt batetries in paralell your cranking amps availability is doubled. I AGREE 100% to first try to remove n clean n wire brush n polish each n every battery n starter n cable n ground connection as posted below and use 00 Gauge cables which can help improve cranking performance. Be sure the ground cable is to a clean rigid main connection instead of any thin or rusty light sheet metal component. A full charged good 6 volt battery ought to read 6.3 volts setting but rise to near 7 or so volts at wide open running throttle if the charging system is allllllllll okay. Make sure the genny belt is good n tight and the genny and VR (if it uses one) are both well grounded. Insure theres electrolyte above all the battery plates and no cells exhibit a gray or milky color and best yet to have a shop LOAD TEST the battery cuz if its weak it may be the cause of poor cranking. Another cause of weak cranking might be a bad starter switch/solenoid you know!!! John T
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
