Re: 1066 International
Posted by JJK on November 25, 2006 at 08:36:57 from (216.189.131.238):
In Reply to: 1066 International posted by Zach Phillips on November 24, 2006 at 15:00:00:
It will work but to much loader work over a period of time will crush the thrust bearings and wear out the spindle bushings faster. Just something to keep an eye on. Also make sure the the bolts for clamping the adjustable axle tube are good and tight so the tube don"t flop. Noticed most when going back and forth and turning at the same time you"ll get a big thunk when it flops. We"ve at times replaced the big clevis pin with a big bolt to help tighten it down more than what just the 2 bolts can do.
